[gdal-dev] Is it possible to optimize vector tiles time writing with MVT driver ?
    Maria Ibarra
    Maria.Ibarra at ign.fr
    Thu Jul 26 06:42:15 PDT 2018
Hello,
I am using the GDAL 2.3.1 MVT driver  to build a vector tile basemap (multiple data layers, at different zoom levels). The process takes 14 hours. However, when I do the same thing using Tippecanoe, it takes one hour and a half.
I’m not sure if I am missing some configuration to reduce the time writing with GDAL.
This is the command I'm using :
ogr2ogr -f MVT <output-folder> PG:<connection to the database> -dsco CONF=<json_conf> -dim 2
where <json_conf> =
    "layer_1": {
        "target_name": "layer_1" ,
        "description": "layer_1" ,
        "minzoom": 13 ,
        "maxzoom": 18
    "layer_2":{
        "target_name": "layer_2" ,
        "description": "layer_2" ,
        "minzoom": 13 ,
        "maxzoom": 18 },
Any advice to optimize vector tile writing process would be helpful.
Thanks,
Maria
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180726/61c5e77f/attachment.html>
