[gdal-dev] OGR SYMBOL style format
Even Rouault even.rouault at spatialys.com
Wed Jun 6 02:18:41 PDT 2018
Gane,
I assume this is with the PDF driver. Yes, size is currently ignored for
raster symbols. Could you file a ticket about that in
https://github.com/OSGeo/gdal/issues/new ?
Your workaround for now is to work with priorly resized images
Even
> Hi,
> I am trying to draw OGR features with style in a defined by a vrt file.
> I want point features to be placed with my custom icon with the OGR Feature
> style.
> So I tried,
> The following line works when I change the size parameter s:n
> SYMBOL(c:#000000FF,s:50px,id:ogr-sym-3);
> The following line doesn't show any change in output image drawn size when
> SYMBOL(c:#000000FF,s:50px,id:bus_stop.png);
> The above line doesn't seem to have any change in the image resize on the
> point locations. But, then I use the default "ogr-sym-3" I see a change in
> the output,
> Did I miss any style parameters or is there any way to have the image
> resized before placing at the location of the point features?
> Thanks
> Gane
http://www.spatialys.com
