[gdal-dev] driver MVT, no tiles generated
Even Rouault even.rouault at spatialys.com
Fri Jun 8 07:26:18 PDT 2018
On vendredi 8 juin 2018 14:17:25 CEST Maria Ibarra wrote:
> I downloaded GDAL from this package
> http://download.osgeo.org/gdal/2.3.0/gdal-2.3.0.tar.gz Built with this
> command :
> ./configure --with-geos=yes with-pg=/usr/bin/pg_config
> sudo make install
OK, the error message shows that GDAL doesn't find PROJ. In your particular
case where your input dataset is already in WebMercator, no reprojection
should normally occur, so that shouldn't matter.
But it would be saner to build GDAL with PROJ support by adding --with-proj to
configure, make clean and re-make
So as that won't likely solve the issue, do you mind sharing your input
dataset, or anyone that would show the issue ? (you can email it privately to
me if you wish)
Even
http://www.spatialys.com
