[gdal-dev] [Gdal-dev] python - reproject a shapefile
Nikos Argiropoulos nickargirop at gmail.com
Sun Jun 10 12:30:29 PDT 2018
As you can see in this
<https://gis.stackexchange.com/questions/285771/gdal-ogr-returning-wrong-reprojected-shapefile>
post,
I try to reproject a shapefile based on the projection info that I get from
a raster, but the output shapefile is completely wrong. I cannot seem to
find a solution to this problem as the code seems to work without errors.
Could you please help?
Thank you in advance!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180610/e64b3d5f/attachment.html>
