[gdal-dev] gdalinfo -mm also report n (number of grid cells that are not nodata)
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Sat Jun 16 09:38:58 PDT 2018
Markus Metz-3 wrote
> My workaround is to use GRASS r.external to get correct raster band
> statistics.
Wouldn't it be good to have an option in GDAL to force it to re-compute
statistics? After all, statistics is just metadata and they can be all wrong
if you have touched the image with a third-party software.
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
