[gdal-dev] CTable2 documentation
Kristian Evers kreve at sdfe.dk
Tue Jun 19 14:07:11 PDT 2018
> That must be some developper sense of humour.
Consider that my attempt at nudging the GDAL community to improve their documentation :-)
/Kristian
> On 19 Jun 2018, at 21:05, Erik Sørngård <erik.sorngard at gl-instrumenter.no> wrote:
> Hello Even,
> Thank you clarifying that PROJ documentation is not accurate. I had seen the source code before, but was hoping for a supporting document as well.
> Based on your input and looking at the source code again today, I expect the data to be stored as longitude and latitude offset pairs, each value being a 32 bit floating point number in radians, with east to west lines, from south to north.
> Regards,
> Erik Sørngård
> R&D Manager
> Gundersen & Løken AS
> E: erik.sorngard at gl-instrumenter.no
> P: +47 22 81 39 94
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at spatialys.com]
> Sent: Tuesday, June 19, 2018 6:14 PM
> To: gdal-dev at lists.osgeo.org
> Cc: Erik Sørngård <erik.sorngard at gl-instrumenter.no>
> Subject: Re: [gdal-dev] CTable2 documentation
> Erik,
>> I have been looking at PROJ's support for grid files, and notice that
>> they refer to "GDAL documentation" for format details about CTable2.
>> While browsing the GDAL site I have so far not been able to locate
>> this information, except for being part of the list of supported file formats:
>> http://www.gdal.org/formats_list.html
>> Where can we find the CTable2 documentation?
> That must be some developper sense of humour. To the best of my knowledge, the best documentation of the CTable2 format is the driver source code:
> https://github.com/OSGeo/gdal/blob/master/gdal/frmts/raw/ctable2dataset.cpp
> Basically there is a 160-byte header, followed by the longitude and latitude offsets, interleaved, and with south-to-north line ordering.
> Even
> Spatialys - Geospatial professional services http://www.spatialys.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
