[gdal-dev] Having trouble working with jp2 files
Even Rouault even.rouault at spatialys.com
Wed Jun 20 07:27:10 PDT 2018
On mardi 19 juin 2018 23:07:24 CEST Stephen Woodbridge wrote:
> I tried the following:
> git clone https://github.com/GeographicaGS/Docker-GDAL2.git
> cd Docker-GDAL2/2.2.4
> #Edit Dockerfile and set 'ENV OPENJPEG_VERSION 2.3.0'
> docker build -t gdal2:local ./
> cd /path/to/jp2
> docker run -t -i gdal2:local -v $(pwd):/data /bin/bash
> gdalinfo -stats /data/850011.jp2
> And got the same errors.
> Even, I sent you a link to download the file from my dropbox.
Steve,
I've investigated and those JPEG2000 files have a particular characteristic
that triggered a regression dating back to openjpeg 2.2.0
I've just fixed it in openjpeg master per
https://github.com/uclouvain/openjpeg/pull/1121
So I'd suggest you to track openjpeg master (or revert back to 2.1.2, but
you'll loose performance optimizations)
Note: the sample file you provided to me has also a non-conformity (declaring
codestream "Profile 0" but with tile dimensions of 1024x1024 instead of
128x128 as expected) in the codestream header, as pointed by Kakadu, but that
is not critical
Even
http://www.spatialys.com
