[gdal-dev] Having trouble working with jp2 files
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Wed Jun 20 09:33:40 PDT 2018
Even,
Thanks!
I did built gdal 2.2.4 with openjpeg 2.1.2 on a docker container and
that solves the simple case of:
gdalinfo -stats /data/850011.jp2
but it still fails with:
root at 436a09289084:/usr/local# gdal_translate -of GTiff -co TILED=YES
/data/850011.jp2 /data/850011.tif
Input file size is 29364, 25856
0ERROR 1: psImage->comps[0].data == NULL
ERROR 1: /data/850011.jp2, band 1: IReadBlock failed at X offset 0, Y
offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
In my Dockerfile, I have:
# Compile and install OpenJPEG
RUN cd src && tar -xvf openjpeg-${OPENJPEG_VERSION}.tar.gz && cd
openjpeg-${OPENJPEG_VERSION}/ \
     && mkdir build && cd build \
     && cmake .. -DCMAKE_BUILD_TYPE=Release
-DCMAKE_INSTALL_PREFIX=$ROOTDIR \
     && make && make install && make clean \
     && cd $ROOTDIR && rm -Rf src/openjpeg*
Any idea how that should change to apply your pull request so I can test
that?
-Steve
$ docker run -v $(pwd):/data -t -i gdal2:local  /bin/bash
root at 436a09289084:/usr/local# gdalinfo -stats /data/850011.jp2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: /data/850011.jp2
        /data/850011.jp2.aux.xml
Size is 29364, 25856
Coordinate System is:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0],
     UNIT["degree",0.0174532925199433],
     AUTHORITY["EPSG","4326"]]
Origin = (50.811767578125000,18.406654712112974)
Pixel Size = (0.000020390753690,-0.000020390753690)
Image Structure Metadata:
   INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  50.8117676,  18.4066547) ( 50d48'42.36"E, 18d24'23.96"N)
Lower Left  (  50.8117676,  17.8794314) ( 50d48'42.36"E, 17d52'45.95"N)
Upper Right (  51.4105217,  18.4066547) ( 51d24'37.88"E, 18d24'23.96"N)
Lower Right (  51.4105217,  17.8794314) ( 51d24'37.88"E, 17d52'45.95"N)
Center      (  51.1111446,  18.1430430) ( 51d 6'40.12"E, 18d 8'34.95"N)
Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
   Min=122.000 Max=254.000
   Minimum=122.000, Maximum=254.000, Mean=204.487, StdDev=9.596
   Overviews: 14682x12928, 7341x6464, 3670x3232, 1835x1616, 917x808
   Overviews: arbitrary
   Metadata:
     STATISTICS_MAXIMUM=254
     STATISTICS_MEAN=204.48710711705
     STATISTICS_MINIMUM=122
     STATISTICS_STDDEV=9.596017845156
     COMPRESSION=JPEG2000
Band 2 Block=1024x1024 Type=Byte, ColorInterp=Green
   Min=98.000 Max=239.000
   Minimum=98.000, Maximum=239.000, Mean=178.492, StdDev=10.197
   Metadata:
     STATISTICS_MAXIMUM=239
     STATISTICS_MEAN=178.49220443461
     STATISTICS_MINIMUM=98
     STATISTICS_STDDEV=10.197171404633
Band 3 Block=1024x1024 Type=Byte, ColorInterp=Blue
   Min=63.000 Max=215.000
   Minimum=63.000, Maximum=215.000, Mean=145.743, StdDev=14.060
   Metadata:
     STATISTICS_MAXIMUM=215
     STATISTICS_MEAN=145.74315841763
     STATISTICS_MINIMUM=63
     STATISTICS_STDDEV=14.060045889747
root at 436a09289084:/usr/local# gdal_translate -of GTiff /data/850011.jp2
/data/850011.tif
offset 0
offset 0
On 6/20/2018 10:27 AM, Even Rouault wrote:
> On mardi 19 juin 2018 23:07:24 CEST Stephen Woodbridge wrote:
>> I tried the following:
>> git clone https://github.com/GeographicaGS/Docker-GDAL2.git
>> cd Docker-GDAL2/2.2.4
>> #Edit Dockerfile and set 'ENV OPENJPEG_VERSION 2.3.0'
>> docker build -t gdal2:local ./
>> cd /path/to/jp2
>> docker run -t -i gdal2:local -v $(pwd):/data /bin/bash
>> And got the same errors.
>> Even, I sent you a link to download the file from my dropbox.
> Steve,
> I've investigated and those JPEG2000 files have a particular characteristic
> that triggered a regression dating back to openjpeg 2.2.0
> I've just fixed it in openjpeg master per
> https://github.com/uclouvain/openjpeg/pull/1121
> So I'd suggest you to track openjpeg master (or revert back to 2.1.2, but
> you'll loose performance optimizations)
> Note: the sample file you provided to me has also a non-conformity (declaring
> codestream "Profile 0" but with tile dimensions of 1024x1024 instead of
> 128x128 as expected) in the codestream header, as pointed by Kakadu, but that
> is not critical
> Even
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
