[gdal-dev] Kriging Interpolation
Chris Marsh chris.marsh at usask.ca
Sun Jun 24 20:29:14 PDT 2018
 For what is worth, as an end-user of GDAL, I would be very interested in
having such capacity in GDAL.
Cheers
Chris
On 24 June 2018 at 21:19, Ian Reese <ireese at linz.govt.nz> wrote:
> Hi Gdal,
> I'd like to know if it is possible to make Kriging Interpolation part of
> gdal_grid.  We work with a good deal of scattered point elevation data and
> neither IDW or Linear interpolations(smooth or not smooth)  produce the
> desired visual results.  Nor are they fast enough for the density of data
> we commonly work with. Linear interpolation is a reliable and fast method,
> however the triangulated results are difficult to work with visually.
> For some visual comparisons and reference, here is a link to a folder of
> sample points(shp) for a test area, two examples of kriged data for that
> test region, and a BASH script to reproduce IDW and Linear interpolations
> of the same region.
> https://drive.google.com/open?id=1HKbK4wMmVN6JZSvhxBQDub1WXBLE710H
> Here is an example of the Kriging method used by ArcGIS:
> http://desktop.arcgis.com/en/arcmap/latest/extensions/
> geostatistical-analyst/kriging-in-geostatistical-analyst.htm
> Few graphs explaining best interpolation methods to use with given data.
> Gridded vs. scattered.
> https://www.neonscience.org/spatial-interpolation-basics
> If it is possible, we are curious to know what type of funding would be
> needed.
> Cheers,
> Ian
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180624/e6b09058/attachment.html>
