[gdal-dev] [gdal-announce] GDAL Support For PostGIS Out-DB Raster
Osahon Oduware osahon.gis at gmail.com
Mon Jun 25 02:18:22 PDT 2018
Hi Even,
I want to find out if this GDAL fix will be release by the end of June. I
use PostGIS version 2.3.2 at present and I will be building from source.
On Thu, May 31, 2018 at 9:39 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 31 mai 2018 21:35:30 CEST Osahon Oduware wrote:
> > Hi Even,
> > Thanks for the prompt response. Please, I want to know what is the
> minimum
> > version of GDAL,
> no released version yet. Will be in 2.3.1 (end of June probably) and 2.4.0
> (next year)
> > PostgreSQL
> irrelevant. Any PostgreSQL version supported by the PostGIS version you
> use is
> fine
> > and Postgis
> will be in Postgis 2.5.0. But not strictly needed. Existing versions will
> work
> too
> > that this outdb raster
> > functionality is currently implemented.
> > Best Regards
> > On May 31, 2018 20:13, "Even Rouault" <even.rouault at spatialys.com>
> wrote:
> > > On jeudi 31 mai 2018 20:04:58 CEST Osahon Oduware wrote:
> > > > Hi Even,
> > > > Any update on this? I have been away for a while.
> > > Yep, support for out-db raster has been added in GDAL master, and
> > > backported
> > > to 2.3 branch as well
> > > See outdb_resolution option in http://gdal.org/frmt_postgisraster.html
> > > 2 new functions added to PostGIS 2.5dev as well to help reading the
> out-db
> > > raster directly from client-side if client and server see the same
> raster.
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180625/d0a955eb/attachment.html>
