[gdal-dev] Kriging Interpolation
Ian Reese ireese at linz.govt.nz
Mon Jun 25 16:16:17 PDT 2018
Cheer Joakim!  That I am not familiar with and will have a look
________________________________________
From: Joaquim Manuel Freire Luís [jluis at ualg.pt]
Sent: Tuesday, 26 June 2018 10:58 a.m.
To: Ian Reese; Even Rouault; gdal-dev at lists.osgeo.org
Cc: Jeremy Palmer
Subject: RE: [gdal-dev] Kriging Interpolation
I have plenty of methods for working around speed issues and have
|>worked with any number of interpolations methods in GRASS, SAGA and
|>Python.
You have also the minimum curvature in GMT. Not lightning fast but quicker than krigging and normally better looking, specially on the extrapolation zones.
Joaquim
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
