[gdal-dev] [gdal-announce] GDAL Support For PostGIS Out-DB Raster
Osahon Oduware osahon.gis at gmail.com
Tue Jun 26 04:39:05 PDT 2018
Hi Even,
I was trying to build GDAL 2.3.1 from source into PostgreSQL 9.6.9 that was
built successfully from source, but I am getting an error when running
"make -j8" (see attachment)
I ran "./configure" successfully with this statement:
./configure --prefix=/home/nagispg/local/gdal213
--with-pg=/home/nagispg/local/pgsql/bin/pg_config
--with-mrsid=/home/nagispg/local/src/MrSID_DSDK-9.5.4.4703-rhel6.x86-64.gcc531/Raster_DSDK
Then I try to run "Make -j8" and I get an error extracted below (see
attachment for more detailed error):
/bin/ld: warning: libpq.so.5, needed by
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so, not found (try using
-rpath or -rpath-link)
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to
`lo_open'
`PQputCopyEnd'
`PQresultErrorMessage'
`PQstatus'
`PQsetNoticeProcessor'
`PQnfields'
`PQgetvalue'
`PQclear'
`PQgetlength'
`PQfmod'
`PQftablecol'
`PQconnectdb'
`PQcmdStatus'
`PQftable'
`PQntuples'
`PQexecParams'
`PQfname'
`PQfinish'
`lo_close'
`PQerrorMessage'
`lo_read'
`PQputCopyData'
`lo_write'
`PQgetResult'
`PQgetisnull'
`PQescapeStringConn'
`PQexec'
`lo_creat'
`PQsetClientEncoding'
`PQftype'
`PQresultStatus'
collect2: error: ld returned 1 exit status
make[1]: *** [gdalserver] Error 1
Please, could you point me to the likely cause of this error. I look
forward to hearing from you.
On Mon, Jun 25, 2018 at 12:43 PM, Osahon Oduware <osahon.gis at gmail.com>
wrote:
> Hi Even,
> Thanks a lot. This is great news! I will start investigating the fix for
> Out-DB rasters. I will keep you posted. Great work!
> On Mon, Jun 25, 2018 at 10:26 AM, Even Rouault <even.rouault at spatialys.com
> > wrote:
>> On lundi 25 juin 2018 10:18:22 CEST Osahon Oduware wrote:
>> > Hi Even,
>> > I want to find out if this GDAL fix will be release by the end of June.
>> I
>> > use PostGIS version 2.3.2 at present and I will be building from source.
>> Yes, this is in the release notes of the release candidate of GDAL 2.3.1
>> that
>> was published last Friday:
>> https://trac.osgeo.org/gdal/wiki/Release/2.3.1-News
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180626/6e5dbe91/attachment-0001.html>
/bin/ld: warning: libpq.so.5, needed by /home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so, not found (try using -rpath or -rpath-link)
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `lo_open'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQputCopyEnd'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQresultErrorMessage'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQstatus'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQsetNoticeProcessor'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQnfields'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQgetvalue'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQclear'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQgetlength'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQfmod'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQftablecol'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQconnectdb'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQcmdStatus'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQftable'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQntuples'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQexecParams'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQfname'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQfinish'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `lo_close'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQerrorMessage'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `lo_read'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQputCopyData'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `lo_write'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQgetResult'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQgetisnull'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQescapeStringConn'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQexec'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `lo_creat'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQsetClientEncoding'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQftype'
/home/nagispg/local/src/gdal-2.3.1/.libs/libgdal.so: undefined reference to `PQresultStatus'
make[1]: *** [gdal_translate] Error 1
make[1]: *** [gdaladdo] Error 1
make[1]: Leaving directory `/home/nagispg/local/src/gdal-2.3.1/apps'
make: *** [apps-target] Error 2
