[gdal-dev] Missing layers with GeoPDF to MVT conversion with ogr2ogr/gdal 2.3.0
Even Rouault even.rouault at spatialys.com
Fri Jun 29 03:14:58 PDT 2018
Max,
I've pushed a fix (in master and release/2.3 branches) in the drawing
instruction parser of the PDF driver that enables to read that file
$ ogrinfo ~/gdal/data/pdf/340711752_Azusa_FSTopo.pdf
1: Other_5
2: Quadrangle_Extent_Other_4
3: Quadrangle_Extent_State_Outline
4: Adjacent_Quadrangle_Diagram_Other_3
5: Adjacent_Quadrangle_Diagram_Quadrangle_Extent
6: Adjacent_Quadrangle_Diagram_Quad_Outlines
7: Quadrangle_Other
8: Quadrangle_Labels_Unplaced_Labels_Road_Shields_-_Vertical
9: Quadrangle_Labels_Road_Shields_-_Horizontal
10: Quadrangle_Labels_Road_Shields_-_Vertical
11: Quadrangle_Neatline/Mask_Neatline
12: Quadrangle_Neatline/Mask_Mask
13: Quadrangle_Culture_Features
14: Quadrangle_Large_Tanks
15: Quadrangle_Linear_Transportation_Features
16: Quadrangle_Railroads_
17: Quadrangle_Linear_Culture_Features
18: Quadrangle_Linear_Landform_Features
19: Quadrangle_Boundaries
20: Quadrangle_PLSS
21: Quadrangle_Survey_Lines
22: Quadrangle_Linear_Drainage_Features
23: Quadrangle_Contour_Labels
24: Quadrangle_Contours
25: Quadrangle_2_5`_Tics_Interior_Grid_Intersections
26: Quadrangle_2_5`_Tics_Grid_Tics_along_Neatline
27: Quadrangle_UTM_Grid_Interior_Grid_Intersections
28: Quadrangle_UTM_Grid_Grid_Tics_along_Neatline
29: Quadrangle_UTM_Grid_UTM_Grid_Lines
30: Quadrangle_Large_Buildings
31: Quadrangle_Drainage_Polygons
32: Quadrangle_Ownership
33: Quadrangle_Builtup_Areas
34: Quadrangle_WoodlandUSGS_P
Some of the layers are missing, but either they are not terminal, or contain
only objects that OGR cannot handle (labels e.g.)
Even
> Hi, I am trying to convert USFS FSTopo GeoPDFs into Mapbox Vector Tiles
> like this:
> $ wget
> https://data.fs.usda.gov/geodata/rastergateway/data/34117/fstopo/340711752_A
> zusa_FSTopo.pdf $ ogr2ogr -f MBTILES test.mbtiles 340711752_Azusa_FSTopo.pdf
> I'm using gdal git master (GDAL 2.4.0dev-1f6d597, released 2018/06/28) with
> poppler 0.64.0.
> My issue is that when I view the mbtiles in a webgl map (using $
> tileserver-gl-light test.mbtiles) I only see 13 layers, not the 59 I was
> expecting. Is it possible to include the vector information in all the
> GeoPDF metadata layers when converting to MVT? I tried adding `--config
> OGR_PDF_READ_NON_STRUCTURED YES` to the end of my ogr2ogr command but it
> had no effect.
> ogrinfo shows 59 metadata layers and 13 top level named layers:
> $ ogrinfo -mdd layers 340711752_Azusa_FSTopo.pdf
> INFO: Open of `340711752_Azusa_FSTopo.pdf'
>       using driver `PDF' successful.
> Metadata:
>   CREATION_DATE=D:20171221174439Z
>   CREATOR=Esri ArcSOC 10.3.1.4959
>   NEATLINE=POLYGON ((407183.394216688 3775784.59268212,407183.480495386
> 3790905.61434883,420034.534067471 3790905.80204647,420034.842839467
> 3775784.26947838,407183.394216688 3775784.59268212))
> Metadata (layers):
>   LAYER_00_NAME=Other_5
>   LAYER_01_NAME=Quadrangle_Extent
>   LAYER_02_NAME=Quadrangle_Extent.Labels
>   LAYER_03_NAME=Quadrangle_Extent.Labels.State_Outline_-_Default
>   LAYER_04_NAME=Quadrangle_Extent.Other_4
>   LAYER_05_NAME=Quadrangle_Extent.State_Outline
>   LAYER_06_NAME=Adjacent_Quadrangle_Diagram
>   LAYER_07_NAME=Adjacent_Quadrangle_Diagram.Other_3
>   LAYER_08_NAME=Adjacent_Quadrangle_Diagram.Labels
>   LAYER_09_NAME=Adjacent_Quadrangle_Diagram.Labels.Quad_Outlines_-_Default
>   LAYER_10_NAME=Adjacent_Quadrangle_Diagram.Quadrangle_Extent
>   LAYER_11_NAME=Adjacent_Quadrangle_Diagram.Quad_Outlines
>   LAYER_12_NAME=Other_2
>   LAYER_13_NAME=Quadrangle
>   LAYER_14_NAME=Quadrangle.Other
>   LAYER_15_NAME=Quadrangle.Labels
>   LAYER_16_NAME=Quadrangle.Labels.Unplaced_Labels
>   LAYER_17_NAME=Quadrangle.Labels.Unplaced_Labels.Road_Shields_-_Vertical
>   LAYER_18_NAME=Quadrangle.Labels.Road_Shields_-_Horizontal
>   LAYER_19_NAME=Quadrangle.Labels.Road_Shields_-_Vertical
>   LAYER_20_NAME=Quadrangle.Labels.Road_Shields_-_Default
>   LAYER_21_NAME=Quadrangle.Neatline/Mask
>   LAYER_22_NAME=Quadrangle.Neatline/Mask.Grid_Labels
>   LAYER_23_NAME=Quadrangle.Neatline/Mask.Neatline
>   LAYER_24_NAME=Quadrangle.Neatline/Mask.Mask
>   LAYER_25_NAME=Quadrangle.Text
>   LAYER_26_NAME=Quadrangle.Road_Shields
>   LAYER_27_NAME=Quadrangle.Buildings
>   LAYER_28_NAME=Quadrangle.Culture_Features
>   LAYER_29_NAME=Quadrangle.Drainage_Features
>   LAYER_30_NAME=Quadrangle.Large_Tanks
>   LAYER_31_NAME=Quadrangle.Survey_Points
>   LAYER_32_NAME=Quadrangle.Geodetic_Control
>   LAYER_33_NAME=Quadrangle.Recreation/Facility_Features
>   LAYER_34_NAME=Quadrangle.Transportation_Features
>   LAYER_35_NAME=Quadrangle.Linear_Transportation_Features
>   LAYER_36_NAME=Quadrangle.Railroads_
>   LAYER_37_NAME=Quadrangle.Linear_Culture_Features
>   LAYER_38_NAME=Quadrangle.Linear_Landform_Features
>   LAYER_39_NAME=Quadrangle.Boundaries
>   LAYER_40_NAME=Quadrangle.Boundaries
>   LAYER_41_NAME=Quadrangle.PLSS
>   LAYER_42_NAME=Quadrangle.Survey_Lines
>   LAYER_43_NAME=Quadrangle.Linear_Drainage_Features
>   LAYER_44_NAME=Quadrangle.Contour_Labels
>   LAYER_45_NAME=Quadrangle.Contours
>   LAYER_46_NAME=Quadrangle.2_5`_Tics
>   LAYER_47_NAME=Quadrangle.2_5`_Tics.Interior_Grid_Intersections
>   LAYER_48_NAME=Quadrangle.2_5`_Tics.Grid_Tics_along_Neatline
>   LAYER_49_NAME=Quadrangle.UTM_Grid
>   LAYER_50_NAME=Quadrangle.UTM_Grid.Interior_Grid_Intersections
>   LAYER_51_NAME=Quadrangle.UTM_Grid.Grid_Tics_along_Neatline
>   LAYER_52_NAME=Quadrangle.UTM_Grid.UTM_Grid_Lines
>   LAYER_53_NAME=Quadrangle.Large_Buildings
>   LAYER_54_NAME=Quadrangle.Culture_Features
>   LAYER_55_NAME=Quadrangle.Landforms
>   LAYER_56_NAME=Quadrangle.Drainage_Polygons
>   LAYER_57_NAME=Quadrangle.Ownership
>   LAYER_58_NAME=Quadrangle.Builtup_Areas
>   LAYER_59_NAME=Quadrangle.WoodlandUSGS_P
> 1: Quadrangle_Culture_Features
> 2: Quadrangle_Contour_Labels
> 3: Quadrangle_Contours
> 4: Quadrangle_2_5`_Tics_Interior_Grid_Intersections
> 5: Quadrangle_2_5`_Tics_Grid_Tics_along_Neatline
> 6: Quadrangle_UTM_Grid_Interior_Grid_Intersections
> 7: Quadrangle_UTM_Grid_Grid_Tics_along_Neatline
> 8: Quadrangle_UTM_Grid_UTM_Grid_Lines
> 9: Quadrangle_Large_Buildings
> 10: Quadrangle_Drainage_Polygons
> 11: Quadrangle_Ownership
> 12: Quadrangle_Builtup_Areas
> 13: Quadrangle_WoodlandUSGS_P
> Thank you,
> Max
http://www.spatialys.com
