[gdal-dev] QGIS3 - Save Map as Image dialog bug?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Mar 1 02:42:18 PST 2018
Do not cross post. If you are rather sure that you have found a bug, as I feel in your case, I suggest to write to the developers list. If there is a chance that you perhaps did something wrong it is good to write to the users list. There are more people there than in the developers list, some user may know the answer for  you, your problem may teach something for other users, and in the ideal world the developers are also reading the users mails.
-Jukka Rahkonen-
Lähettäjä: Idan Miara [mailto:idan at miara.com]
Lähetetty: 1. maaliskuuta 2018 12:34
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] QGIS3 - Save Map as Image dialog bug?
Yes it did sent it intentionally to this list, but I was wandering if it's more a developer-list or a user-list question.
Did you mean that I should have better post it on both lists or that there is a combined list?
On 1 March 2018 at 12:27, jratike80 <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
Idan Miara wrote
> Hi,
> i think there is a bug in the Save Map as Image dialog in QGIS3:
Did you intentially write to GDAL-devel list? I believe that
QGIS-users/developers would be a better choice.
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180301/dcce0722/attachment-0001.html>
