[gdal-dev] Troubleshooting palette management. Potential bug in palette for overviews?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Mar 8 07:00:16 PST 2018
You are the man!
Thanks for that.
Do you know which GDAL versions will contain the fix?
Cheers,
Daniele
On Thu, Mar 8, 2018 at 3:55 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 8 mars 2018 15:32:09 CET Daniele Romagnoli wrote:
> > Hi Even,
> > I'm resurrecting this old post since I think we have (GeoServer) been hit
> > by that problem again (although I'm not 100% sure about that).
> > http://osgeo-org.1560.x6.nabble.com/Geotiff-pyramids-
> non-transparant-while-o
> > riginal-is-transparent-td5357343.html
> > Do you know if there is any plan to fix https://trac.osgeo.org/gdal/
> > ticket/2213?
> Daniele,
> there was no "plan", but seing this is a 10-year long lasting issue made
> me sad, so I've just pushed a fix... As suggested in this discussion
> thread, I've used 257 as factor for multiplication/division hopefully all
> over the relevant places.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180308/81c706cc/attachment.html>
