[gdal-dev] GDAL python bindings build error (gcc command replaced by bash)
Even Rouault even.rouault at spatialys.com
Wed Mar 14 13:15:41 PDT 2018
Guillaume,
Does adding the following in swig/python/setup.py  (just after similar stuff for CXX) helps ?
if 'CC' in os.environ and os.environ['CC'].strip().find(' ') >= 0:
    print('WARNING: "CC=%s" was defined in the environment and contains more than one word. Unsetting it since that is incompatible of distutils' % os.environ['CC'])
    del os.environ['CC']
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180314/f887902a/attachment.html>
