[gdal-dev] gdal translate/warp goes16
Steven Beale steven.beale at woodplc.com
Tue Mar 20 11:37:34 PDT 2018
Hi gdalers,
I'm a little out of my field here, usually I work with weather/climate data,
but I need to warp some goes16 satellite data. (source is aws s3:
https://noaa-goes16.s3.amazonaws.com/ABI-L2-CMIPF/2018/079/12/OR_ABI-L2-CMIPF-M3C01_G16_s20180791200447_e20180791211214_c20180791211280.nc
- the link should work for a few months then it will be glaciered and
unavailable)
source data is netcdf, I'm using nco tools & gdal for the processing.
My work flow is:
1. clip the data to the region of interest (north atlantic):
ncks -d x,5424,8678 -d y,0,2170 <raw.nc> step1.nc
2. deflate & unscale
gdal_translate -ot float32 -unscale -CO COMPRESS=deflate NETCDF:step1.nc:CMI
step2.tiff
3. warp (in this case data is 1km resolution : ~0.009 degrees)
gdalwarp -t_srs EPSG:4326 -dstnodata -999.0 -tr 0.009 0.009 -te 290 40 320
65  -r near step2.tiff step3.tiff
4. convert back to nc
gdal_translate -ot float32 -of NETCDF step3.tiff output.nc
The problem i have is that the output has the longitude shifted to the west
by about 10 degrees.
The issue seems related to the ncks clipping, if I exclude the x clip,
everything works out fine, but takes significantly longer.
Here's an example once it's loaded into an erddap server;
<http://osgeo-org.1560.x6.nabble.com/file/t382897/GOES16_L2CMIPF_M3C01_201803201200.png>
You can see greenland to the west of it's map underlay.
I'm using gdal v2.3.0, netcdf v4.4.1.1, nco v4.7.3 & proj4 v5.0.0
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
