[gdal-dev] Trac to GitHub
Mateusz Loskot mateusz at loskot.net
Thu Mar 22 10:44:39 PDT 2018
On 22 March 2018 at 17:17, Even Rouault <even.rouault at spatialys.com> wrote:
> I've prototyped what should be the new repository (baring any new commits in the meantime) and
> put it temporarily at https://github.com/rouault/gdal_wip
> You can check if branches, tags etc look good. I've removed a few useless branches and tags.
> Branches are named release/{major}.{minor} and tags v{major}.{minor}.{micro}
Looks good!
For a few branches, I've checked that
in release/X.Y branch
number in VERSION file
matches latest vX.Y.Z tag
Once again, big thank you Even!
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
