[gdal-dev] Concurrent and efficient access to features in OGRLayer
Julien Michel julien.michel at cnes.fr
Fri Mar 23 01:30:30 PDT 2018
Hi Even,
Thank you very much for your answers. Please find some comments enclosed.
Regards,
Julien
Le 21/03/2018 à 11:09, Even Rouault a écrit :
>> I am writing some code that processes features from a Layer, and I am
>> facing two distinct problems :
>> 1) Since the processing of features might be heavy, I would like to do
>> some parallel processing, but I did not find any way to iterate on
>> features in parallel, even for read-only / in-memory datasets. Do you
>> have any idea on how I could achieve that ?
> Some drivers might have an efficient implementation of SetNextByIndex(), so
> you could use that to open the same dataset as many times as needed, position
> the reading cursor with SetNextByIndex() at different indexes in the different
> threads, and then iterate with GetNextFeature()
> Another approach would be to have a single reader (as most of the time
> iterating over source features is really neglectable comparing to the
> processing done with them), and then push them to a queue that is consumed by
> several processing threads. That's more or less what I've done recently in the
> writer side of the MVT driver: the CreateFeature() method pushes the features
> to a queue, and different worker threads consume this queue and process them.
That is pretty much what I did, however I was looking for a way to avoid
extra copies of features (maybe I am doing this wrong).
>> 2) I am using spatial filtering to retrieve a subset of the features
>> corresponding to a given area, and then iterate on the area to process.
>> My code therefore uses spatial filters quite intensively, which might be
>> very slow without spatial indexing and a large number of features. Is
>> there a way to add spatial indexing for in memory dataset ?
> If you are thinking about the MEM driver, there's no implementation of spatial
> indexing in it currently.
> If you are using GeoPackage or Shapefiles stored in /vsimem/, then spatial
> indexes if they exist will be used.
Would there be any interest in developing spatial indexing for the MEM
driver ? How difficult is it to implement it ?
Regards,
Julien
Julien MICHEL
CNES - DSO/SI/2A
