[gdal-dev] https://github.com/OSGeo/gdal is the current SCM and ticketing system
Sean Gillies sean at mapbox.com
Fri Mar 23 08:18:17 PDT 2018
Thanks, Even and team!
I've followed the contributing directions and am all set to contribute.
It'll be great to be able to integrate Rasterio and GDAL issues. This move
hugely benefits some of my projects and I am very grateful for it. I've
complained about the friction of contributing to GDAL in the past and will
now put my money where my mouth was, so to speak.
On Fri, Mar 23, 2018 at 8:09 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> OK, so now you can and should use https://github.com/OSGeo/gdal to track
> developement and file new tickets/issues
> Trac ticket creation has been disabled. You can still modify existing
> tickets.
> One side effect of pushing the rewritten commit messages is that all still
> opened pull requests (~20) in the previous mirror have been forced closed
> (not
> surprising since the sha1sum of the base commits have been modified). So if
> you had pending work, please rebase it on top of the current
> https://github.com/OSGeo/gdal and issue a new pull request. Forks of the
> previous https://github.com/OSGeo/gdal will probably have to be recreated
> from
> scratch, or "rebased" to the current one as well.
> The cron job that triggers website refresh has now been updated.
> GDAL SVN committers that don't have yet push rights to github, please
> submit a
> pull request to gdal/COMMITTERS file with a new line with your contact
> information, so your github nickname can be added to the authorized list of
> people with push rights (if you already have push rights, please also
> update
> COMMITTERS with your info)
> I've updated a few things on Trac wiki to point to github. If you still see
> references to svn or Trac for new tickets, you're welcome to fix them.
> I've initiated
> https://github.com/OSGeo/gdal/blob/master/CONTRIBUTING.md
> Needs more love.
> Kyle, you'll likely need to update your job for Coverity Scan.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180323/d7ba3296/attachment-0001.html>
