[gdal-dev] https://github.com/OSGeo/gdal is the current SCM and ticketing system
Mateusz Loskot mateusz at loskot.net
Sat Mar 24 11:33:39 PDT 2018
On 23 March 2018 at 15:09, Even Rouault <even.rouault at spatialys.com> wrote:
> OK, so now you can and should use https://github.com/OSGeo/gdal to track
> developement and file new tickets/issues
> Trac ticket creation has been disabled. You can still modify existing tickets.
Great, thank you!
> GDAL SVN committers that don't have yet push rights to github, please submit a
> pull request to gdal/COMMITTERS file with a new line with your contact
> information, so your github nickname can be added to the authorized list of
> people with push rights (if you already have push rights, please also update
> COMMITTERS with your info)
FYI, I have rearranged the GDAL teams on GitHub slightly:
The master GDAL team has no access to OSGeo/gdal repository,
it does not need one, it just manages sub-teams and members
https://github.com/orgs/OSGeo/teams/gdal/
New sub-team gdal-admins has full admin access to OSGeo/gdal repo
(all members move from the pevious global GDAL team)
https://github.com/orgs/OSGeo/teams/gdal-admins/
The gdal-committers team has moved under the umbrella of GDAL master team
and has read-write access to OSGeo/gdal repo
https://github.com/orgs/OSGeo/teams/gdal-committers/
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
