[gdal-dev] https://github.com/OSGeo/gdal is the current SCM and ticketing system
Mateusz Loskot mateusz at loskot.net
Sat Mar 24 13:47:19 PDT 2018
On 24 March 2018 at 21:12, Even Rouault <even.rouault at spatialys.com> wrote:
>> What is the status of the nightly builds now?
> Same as before: broken for years now.
Even,
Ha, I should have noticed :)
> As it was just a snapshot of the
> repository source code, and that can be done easily from github UI, there's
> little point in resurecting a script for that IMHO
OK
>> Does this [1] mean Trac wiki to GitHub wiki would require a new RFC?
> We need some discussion indeed about that I believe. Some current wiki content
> could be worth being part of official documentation ( thinking to https://
> trac.osgeo.org/gdal/wiki/ConfigOptions for example ), so hosted in the git
> repo itself. There were similar discussions when proj went from Trac to GH.
> Some wiki content was migrated to GH Wiki but I think some also was migrated
> to the revamped documentation (which has been a significant effort).
Good point, that could be the case for GDAL too.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
