[gdal-dev] https://github.com/OSGeo/gdal is the current SCM and ticketing system
Mateusz Loskot mateusz at loskot.net
Mon Mar 26 16:20:49 PDT 2018
On 23 March 2018 at 15:09, Even Rouault <even.rouault at spatialys.com> wrote:
> OK, so now you can and should use https://github.com/OSGeo/gdal to track
> developement and file new tickets/issues
Even,
FYI, if you'd like to create issues labelling scheme different than the modest
default, here is small Python script that can bulk-manage labels based
on definitions in JSON file(s):
https://github.com/mloskot/github-label-maker
Best regards,,
Mateusz Loskot, http://mateusz.loskot.net
