[gdal-dev] limiting drivers that get registered
Ben Elliston ben.elliston at anu.edu.au
Tue Mar 27 03:51:46 PDT 2018
On 27/03/18 21:49, Even Rouault wrote:
> Hum why would you need to call GDALAllRegister() if you already manually
> registered some of them ?
Because reordering the driver list by placing commonly used drivers at
the head of the list makes a significant difference in the time taken to
open files.
> Well, call GDALAllRegister() and then query GDALGetDriverByName(driver_name).
> You can unregister a driver with GDALDeregisterDriver()
Thanks -- you've given me an idea ..
Cheers, Ben
