[gdal-dev] limiting drivers that get registered
Ben Elliston ben.elliston at anu.edu.au
Tue Mar 27 05:04:38 PDT 2018
On 27/03/18 22:00, Even Rouault wrote:
> Ah that was apparently your actual need rather than limiting the number of
> drivers per-se. Do you have profiled where time was lost if you find opening
> too slow ? The identification logic of drivers is supposed to operate fast
> (extension based, or on the content of the first kilobyte of the header), but
> there might be some drivers where improvements can be done.
I wrote a pathological benchmark that opened and closed an HDF5 file
10,000 times. Moving the HDF5 driver to the head of the driver list gave
about a 5x speedup.
Thanks for the idea earlier. I came up with an acceptable solution:
register all drivers, look to see which ones are present by using
GDALGetDriverShortName(), and then de-register all the drivers.
Cheers, Ben
