[gdal-dev] deb package for 2.2.3
Grégory Bataille gregory.bataille at gmail.com
Thu May 3 22:39:50 PDT 2018
wow, ok, a bit more work than I expected. Now I understand why it's hard to
keep it up-to-date.
Thanks for the osgeolive pointer, did not know about it.
Cool if you move soon to 2.3.0 and therefore feeds ubuntugis. I'll still
see if I can quickly get somewhere is the meantime on my own with what you
sent
cheers
Gregory Bataille
On Fri, May 4, 2018 at 7:28 AM Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 05/04/2018 07:11 AM, Grégory Bataille wrote:
> > I'm running gdal 2.2.2 from ubuntu-gis/experimental .deb package and I
> just
> > got stuck by https://trac.osgeo.org/gdal/ticket/7143.
> > Took me some time to debug because I develop locally on Mac, where the
> > package is at 2.2.3 and the bug is fixed.
> > What does it take to build the .deb package. Is this something that
> someone
> > can do? is this something sufficiently scripted that I can do it and give
> > you guys the result for publication?
> In the case of UbuntuGIS, you can rebuild the source package from
> Debian. The sources are available in git:
>  https://salsa.debian.org/debian-gis-team/gdal
>  https://salsa.debian.org/debian-gis-team/gdal-grass
> Once you have rebuild the gdal package, you need to rebuild all reverse
> dependencies (packages that depend on libgdal20) with the new gdal to
> have them use the new virtual ABI dependency.
> Because of interdependencies you need to rebuild the packages in the
> correct order, have a look at:
>  https://trac.osgeo.org/ubuntugis/wiki/BuildOrder
> Note that this page may have become outdated again. The Debian GIS
> transition trackers shows all libgdal20 reverse dependencies in Debian
> unstable:
>  https://linuxminded.nl/debian/gis-transitions/html/gdal.html
> You will need to host all the rebuild packages in your own PPA to easily
> install them. If your goal is to update the gdal packages in the
> UbuntuGIS PPA, you need to coordinate your contributions on the
> appropriate mailinglist:
>  https://lists.osgeo.org/mailman/listinfo/ubuntu
> Due to the lack of manpower, pretty much all the packages in the
> UbuntuGIS PPA get copied from the OSGeoLive PPA where a little more
> manpower is available to create backports of Debian GIS packages for
> Ubuntu LTS releases.
> The next OSGeoLive release will be based on bionic, and will rely for a
> large part on the packages already available in Ubuntu because they're
> up-to-date with the latest upstream releases. At least proj & gdal will
> most likely be updated to 5.0.1 & 2.3.0 for OSGeoLive 12.0. So you can
> also just wait for those packages to find their way from the OSGeoLive
> PPA to the UbuntuGIS PPA. Contributing to OSGeoLive is also most welcome.
> Kind Regards,
> Bas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180504/81b6c956/attachment-0001.html>
