[gdal-dev] connect mssql from linux
Even Rouault even.rouault at spatialys.com
Sun May 6 14:22:18 PDT 2018
On dimanche 6 mai 2018 23:06:54 CEST Martin Landa wrote:
> Hi,
> 2018-05-06 13:06 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> For record, I managed to connect to MSSQL DB using tdsodbc
> sudo apt install unixodbc freetds-bin tdsodbc
> [SQL Server]
> Description = FreeTDS driver
> Driver = /usr/lib/x86_64-linux-gnu/odbc/libtdsodbc.so
> Setup = /usr/lib/x86_64-linux-gnu/odbc/libtdsS.so
> FileUsage = 1
> UsageCount = 1
> It works perfectly!
Would be a good hint for the driver documentation page.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180506/948fc461/attachment.html>
