[gdal-dev] How to debug the shape open option "encoding"?
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Fri May 11 11:11:36 PDT 2018
Andrew C Aitchison-2 wrote
> On Fri, 11 May 2018, Rahkonen Jukka (MML) wrote:
>> For example in my case I had to use exactly "-oo encoding="ISO_8859-1".
> ... with an odd number of quotes ? Wierd.
Sorry for lazy proof reading. In the command line exactly
In http://www.gdal.org/drv_shapefile.html is kind of documentation:
"LDID "87 / 0x57" is treated as ISO8859_1 which may not be appropriate" and
that was the string I used first with poor success.
-Jukka-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
