[gdal-dev] mssql import speed
Tamas Szekeres szekerest at gmail.com
Sat May 12 07:17:37 PDT 2018
Hi Martin,
Can I get the sample data for this?
Looks like more than one table is set "IDENTITY_INSERT ON" at the same time.
Best regards,
Tamas
2018-05-12 16:10 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2018-05-12 15:51 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> > ERROR 1: Failed to set identity insert on layer, [Microsoft][SQL Server
> Native C
> > lient 11.0][SQL Server]IDENTITY_INSERT is already ON for table
> 'kn2.dbo.par'. Ca
> > nnot perform SET operation for table 'dbo.bud'..
> > ERROR 1: Unable to write feature 1 from layer BUD.
> > ERROR 1: Terminating translation prematurely after failed
> > translation of layer BUD (use -skipfailures to skip errors)
> Input DB has about 50 layers, see
> 1: PAR (None)
> 2: BUD (None)
> 3: ZPOCHN (None)
> It seems that all records from PAR layer are sucessfully writen to
> target PAR table in MSSQL. Writing features from second layer (BUD)
> fails. No records written. It must be related to BCP. Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180512/f0abacab/attachment-0001.html>
