[gdal-dev] mssql import speed
Tamas Szekeres szekerest at gmail.com
Sun May 13 13:36:07 PDT 2018
Hi Martin,
Thanks for the data.
Fixed this one in this PR:
https://github.com/OSGeo/gdal/pull/621
Best regards,
Tamas
2018-05-12 21:59 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2018-05-12 16:17 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
> > Can I get the sample data for this?
> sure [1].
> > Looks like more than one table is set "IDENTITY_INSERT ON" at the same
> time.
> Steps to reproduce (tested with SQL Server 2014):
> 1) create new mssql db
> 2) C:\OSGeo4W64/apps/gdal-dev/bin/ogr2ogr -f MSSQLSpatial --config
> GDAL_DRIVER_PATH C:\OSGeo4W64\apps\gdal-dev\bin\gdalplugins --config
> MSSQLSPATIAL_LIST_ALL_TABLES YES %connstr% %filedb%
> Thanks! Martin
> [1] http://geo102.fsv.cvut.cz/~landa/tmp/Export_vse.db.7z
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180513/050c8326/attachment.html>
