[gdal-dev] Coordinate system improvements - GDAL, libgeotiff, PROJ barn raising
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue May 15 08:32:37 PDT 2018
Congratulations and thanks to all the sponsors!
Best,
Angelos
On Tue, May 15, 2018 at 6:27 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi all,
> Excellent news: the last third of the funding was completed yesterday, so
> this project will come true ! Thanks to all sponsors who have contributed
> making this possible [1]
> So what does this mean for GDAL ? Obviously all the functionality
> mentionned below will become available once implemented.
> Most of the initial work will be done in PROJ first, with GDAL catching it
> up afterwards (or in an experimental branch at first to follow the "eat
> your own dog food" principle). I'll come back later with more concrete
> implementation plans.
> I guess some disruption is to be expected temporarily as functionnality
> will move from GDAL down to PROJ. This will probably mean that PROJ master
> will be a required dependency for GDAL master (and PROJ 6.0 a minimum and
> compulsory requirement for GDAL 2.4)
> Best regards,
> Even
> [1]
> (Anonymous)
> AppGeo
> Applied Imagery
> Azavea
> Boundless
> Carto
> ESRI
> GeoCue
> LizardTech
> LINZ
> Mapbox
> Mobile Geographics
> Oslandia
> Safe Software
> Sparkgeo
> Spatial Networks
> Radiant Solutions
> Terranodo
> The Timoney Group
> > Hi,
> > A barn raising to improve coordinate system abilities in GDAL,
> libgeotiff,
> > and PROJ has been publicly launched today. You can find more details
> about
> > the proposal, its current sponsors and technical information at:
> > https://gdalbarn.com
> > The hightlights of the planned work are:
> > * migration for CSV support data to a SQLite database shared between
> > projects, offering more capabilities
> > * WKT2 support: increased interoperability between implementations.
> better
> > ground for definitions, especially in areas such as axis, vertical
> control,
> > and epochs
> > * end of WGS84 as a compulsory datum pivot, to be replaced by
> "late-binding"
> > transformations that PROJ.5 now allows.
> > We are currently at 2/3 of the final funding goal. If your software and
> > projects benefit from the GDAL, libgeotiff and PROJ stack, this is your
> > chance to concretely help in its future improvements.
> > Best regards,
> > Howard Butler
> > Kristian Evers
> > Paul Ramsey
> > Even Rouault
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180515/45ea5253/attachment.html>
