[gdal-dev] installed header files
Ari Jolma ari.jolma at gmail.com
Thu May 17 05:28:52 PDT 2018
In 2.3 the installed header files is limited to a fixed list. That is a
good thing. Even better would be to install the header files into a GDAL
specific subdir.
However, that change broke one thing: the bindings cannot now be built
against the public header files. At least cpl_vsi_error.h is needed(1).
But, I'm wondering should the bindings be separately buildable anyway.
The bindings are pretty much married to the specific version of the
source tree.
The case above is a CI run where I'm building the Perl bindings
separately with the help of another Perl module (Alien::gdal), which
does the actual download-build workflow for GDAL. The reason for this is
to have the GDAL Perl bindings in CPAN as a stand-alone and testable
module. That's a good reason, however, I'm moving to recommending using
the FFI based module (Geo-GDAL-FFI), which is more robust and doesn't
need the header files to install and run.
Ari
(1) https://api.travis-ci.org/v3/job/380159862/log.txt
