[gdal-dev] Interesting issue with ogr2ogr and -tps
Even Rouault even.rouault at spatialys.com
Fri May 18 09:19:28 PDT 2018
Martin,
Patch applied. Thanks !
Even
> I had a similar problem when not using armadillo, but a simple
> transformation does the trick. The problem is that usually the distance of
> different gcps compared their absolute value is very small.
> This leads to a bad conditioned linear equation system (see
> https://en.wikipedia.org/wiki/Condition_number): The first column consists
> of 1s and the second and third of the x, y values of the gcps respectively.
> Now if the difference of the gcps is relatively small the second and third
> row are nearly colinear to the first one, hence the matrix is nearly
> singular.
> The solution is to shift the coordinate system by the mean value of all gcps
> and solving the modified linear equations. Since the basis function of the
> TPS only depends on the difference of coordinates the resulting
> transformation is the same.
> For the implementation details see the attached patch file.
> Martin
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180518/a53460b0/attachment.html>
