[gdal-dev] CPLStat + VSI_REG fails on larger files on Windows
    Even Rouault
    even.rouault at spatialys.com
    Tue May 22 00:18:19 PDT 2018
On mardi 22 mai 2018 08:41:35 CEST Martin Landa wrote:
> https://github.com/OSGeo/gdal/blob/master/gdal/ogr/ogrsf_frmts/vfk/
vfkreader
> .cpp#L82
CPLStat() ultimately calls _wstat() on Windows. Looking at
https://docs.microsoft.com/en-gb/cpp/c-runtime-library/reference/stat-functions
, it seems it can only deal with 32-bit file length
You could just replace your CPLStat() call with VSIStatL() (and use a VSIStatBufL
structure) that will use a 64-bit ready Windows API underneath.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180522/391d0085/attachment.html>
