[gdal-dev] Problems with pct2rgb and gdal_translate
Aklim anna.maria.klimkowska at gmail.com
Tue May 29 00:09:42 PDT 2018
Hello.
I try to mosaic images using gdalwrap from following instructions here
https://download.osgeo.org/gdal/workshop/foss4ge2015/workshop_gdal.html#__RefHeading__5961_1333016408
<https://download.osgeo.org/gdal/workshop/foss4ge2015/workshop_gdal.html#__RefHeading__5961_1333016408>
1. problem with pct2rgb
  File "C:\OSGEO4~1\bin\pct2rgb.py", line 121, in <module>
    ct_size = ct.GetCount()
AttributeError: 'NoneType' object has no attribute 'GetCount'
2. problem with gdal_translate (expand rgb)
Input file size is 6085, 7106
ERROR 1: Error : band 1 has no color table
when I check shapes of images I receive following results:
Dimension image 1:
(4, 7106, 6085)
Dimension image 2:
(4, 6928, 7180)
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
