[gdal-dev] [gdal-announce] GDAL Support For PostGIS Out-DB Raster
Even Rouault even.rouault at spatialys.com
Thu May 31 13:39:56 PDT 2018
On jeudi 31 mai 2018 21:35:30 CEST Osahon Oduware wrote:
> Hi Even,
> Thanks for the prompt response. Please, I want to know what is the minimum
> version of GDAL,
no released version yet. Will be in 2.3.1 (end of June probably) and 2.4.0
(next year)
> PostgreSQL
irrelevant. Any PostgreSQL version supported by the PostGIS version you use is
fine
> and Postgis
will be in Postgis 2.5.0. But not strictly needed. Existing versions will work
too
> that this outdb raster
> functionality is currently implemented.
> Best Regards
> On May 31, 2018 20:13, "Even Rouault" <even.rouault at spatialys.com> wrote:
> > On jeudi 31 mai 2018 20:04:58 CEST Osahon Oduware wrote:
> > > Hi Even,
> > > Any update on this? I have been away for a while.
> > Yep, support for out-db raster has been added in GDAL master, and
> > backported
> > to 2.3 branch as well
> > See outdb_resolution option in http://gdal.org/frmt_postgisraster.html
> > 2 new functions added to PostGIS 2.5dev as well to help reading the out-db
> > raster directly from client-side if client and server see the same raster.
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
