[gdal-dev] Alternative to GPKG format
    jratike80
    jukka.rahkonen at maanmittauslaitos.fi
    Thu Nov  1 02:55:44 PDT 2018
koji higuchi wrote
> Hi, following is the code I used:
> Import os, osmium, fiona
> fi = 'europe-latest.osm.pbf'
> fo = 'europe-latest.dpkg'
> drv = 'DPKG'
I am not able to evaluate if your code is effective or not. However, I can
give you some numbers for comparison.
Test data http://download.geofabrik.de/europe/finland-latest.osm.pbf
- 322 MB as .pbf
- 770725 points
- 1778917 lines
- 3128 multilinestrings
- 2087911 multipolygons
- 6985 other relations
Command:
ogr2ogr -f gpkg finland.gpkg finland-latest.osm.pbf
Execution time on Windows laptop:
2 minutes and 20 seconds
If you experience some slower performance it is probably not because of
SQLite/GeoPackage as a format is slow but because something is not done in a
way that is not optimal for the format. Could you also define your source
data and the performance that you have measured?
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
