[gdal-dev] ogr2ogr clip operation very slow compared to QGIS
Even Rouault even.rouault at spatialys.com
Tue Nov 13 07:02:57 PST 2018
Peter,
> I'm trying to clip some GML data via a fairly complex ShapeFile boundary
> using standard ogr2ogr and it is taking roughly 5 minutes before completing
> successfully.
Does your input dataset (input_file.gz) has many features ? (let's say ~1000)
> This same operation takes less than a second using the Clip
> operation in QGIS with exactly the same data. I was lead to believe that
> QGIS is using OGR under the hood to perform the clip operation,
I don't think so. From what I can see, qgsalgorithmclip.cpp in QGIS uses the
same geometry library as OGR, namely GEOS, but doesn't use OGR itself.
> so my
> question is: why is my ogr2ogr clip command taking so much longer?
Looking at QGIS code, it uses GEOS prepared geometry mechanism with the clip
geometry, so as to speed up intersection operations on it. Whereas ogr2ogr -
clipsrc uses the 'naive' intersection function. I guess this is the reason for
the speed difference. QGIS also checks for the result of contains() and
intersects() predicates before calculating the intersection geometry. Not sure
how much that speed-up things. So I bet ogr2ogr could be improved to have
similar performance as QGIS clipping.
Even
http://www.spatialys.com
