[gdal-dev] downsampling geotiff with a low-pass filter
Even Rouault even.rouault at spatialys.com
Fri Nov 16 01:07:45 PST 2018
> Upsampling is well
> covered: cubicspline and lanczos are reasonably sophisticated upsampling
> filters,
Did you actually try them for downsampling ? They are for sure widely used in
that case already, for example when using gdaladdo to create overviews. For
example cubicspline has a filter radius of 2. If you downsample by a factor of
X, the effective radius will be 2 X.
http://www.spatialys.com
