[gdal-dev] NetCDF config option for west > east?
Markus Metz markus.metz.giswork at gmail.com
Sun Nov 25 13:21:51 PST 2018
On Sun, Nov 25, 2018 at 9:49 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> > About the PR: if the tested nc files are formally legal with their
> > longitude jump at 359.95, 0.04998779, then this could be regarded as a
bug
> > fix, right?
> Hard to tell what is legal from what is not sometimes. Anyway the mission
of a
> driver is to make it as easy as possible to use the data that is
available, so
> when "patching" is needed and doable without compromising the reading of
> "normal" products, it is legit to do it. And as the fix is non-intrusive,
I've
> just backported it to the 2.3 branch
Great, thanks for backporting to the 2.3 branch! This makes at least the
CAMS products easily usable, probably also other NetCDF files covering
Europe.
Markus M
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181125/127aa6dd/attachment.html>
