[gdal-dev] Creating external overviews for JP2 files?
Andrea Aime andrea.aime at geo-solutions.it
Mon Oct 8 04:06:10 PDT 2018
On Mon, Oct 8, 2018 at 1:02 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Which which driver ? JP2KAK should already have it, and I've added
> external
> overview building to the JP2OpenJPEG driver in GDAL master a few months
> ago.
Ah, I have the JP2OpenJPEG and the GDAL of my local Mint 19, which is:
> gdalinfo --version
GDAL 2.2.3, released 2017/11/20
So, it seems what I was looking for was not crazy after all :-)
> https://github.com/OSGeo/gdal/commit/98a3985d90c2972e367a484ca40fd86f164721ec
> You could likely cherry-pick it in the 2.3 branch without much trouble.
I see. Could do it locally, but it would be a problem to do on the
production servers (it's a
continuous ingestion system loading copernicus data)
Wondering, would it have any advantage over just doing a gdal_translate
with target size and
then adding overviews on top of it?
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181008/50761d5d/attachment.html>
