[gdal-dev] gdalautotest
Even Rouault even.rouault at spatialys.com
Tue Oct 9 14:39:13 PDT 2018
On mardi 9 octobre 2018 20:09:23 CEST Alan Stewart wrote:
> Okay, found the bindings and bindings_install targets in makefile.vc. The
> bindings target does not build so something is wrong. Mysteriously
> reporting that files are not found, reporting absolute paths for files that
> are in fact there at the reported path... Also Swig.swg and python.swg are
> not found.
try:
set DISTUTILS_USE_SDK=1
set MSSdk=1
cd swig\python
python setup.py build
python setup.py install
> Alan Stewart
> Senior Software Engineer
> TerraGo Technologies
> 3200 Windy Hill Road, Suite 1550W
> Atlanta, GA 30339 USA
> O.  +1 678.391.9615
> www.terragotech.com<applewebdata://B24C0762-C7C9-4431-8518-ACC915448B89/www.
> terragotech.com>
> From: Alan Stewart
> Sent: Tuesday, October 09, 2018 3:38 PM
> To: 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
> Subject: RE: gdalautotest
> Oops, just realized the path I need to add to PYTHONPATH I the parent of
> osgeo. Still fails importing _gdal. Are these files supposed to have been
> installed into my Pyton installation by the install process?
> Alan Stewart
> O.  +1 678.391.9615
> terragotech.com>
> From: Alan Stewart
> Sent: Tuesday, October 09, 2018 3:22 PM
> <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> Subject:
> gdalautotest
> I'd like to run the gdalautotest scripts locally, and add some tests, but
> I've not had success getting the environment set up correctly. I assume
> with the right configuration the build process will generate the Python
> bindings?
> I'm on Windows running in a  VS1027 x86 native tools command prompt. I've
> configured the following environment variables:
> set "GDAL_HOME=C:\devel\GitHub\build"
> set "GDAL_DATA=%GDAL_HOME%\data"
> set "PATH=%PATH%;%GDAL_HOME%\bin"
> set "PYTHONPATH=C:\devel\GitHub\gdal\gdal\pymod"
> My nmake.local contains:
> MSVC_VER=1910
> VERSION=204
> GDAL_HOME="C:\devel\GitHub\build"
> PYDIR="C:\Python27"                                            <-- in the
> PATH inherited by the command prompt SWIG="C:\devel\GitHub\swig.exe"
> BINDINGS=python
> HAVE_NUMPY=1
> I run "nmake -f makefile.vc", then "nmake -f makefile.vc install", then from
> the autotest folder "C:\Python27\python.exe run_all.py". The error is that
> pymod\gdaltest.py cannot import gdal from osgeo.
> I found the gdal\swig\python\osgeo folder and tried adding that to
> PYTHONPATH. Same result.
> Alan Stewart
> O.  +1 678.391.9615
> terragotech.com>
http://www.spatialys.com
