[gdal-dev] Creating external overviews for JP2 files?
Alessandro Parma alessandro.parma at geo-solutions.it
Wed Oct 17 09:22:12 PDT 2018
Hi All,
Sorry for hijacking the thread but I had kind of the "opposite" issue,
trying to achieve the same goal (external overviews for JP2 files) using
the JP2KAK driver instead of JP2OpenJPEG. In my case, it looks like I can
only create the overview files directly using gdaladdo, without doing a
gdal_translate first. If I try to do a gdal_translate first I end up with a
0-fileed file. Let me give an example:
I run gdal_translate first as follows:
gdal_translate -outsize 50% 50% -co TILED=YES -co COMPRESS=JPEG -co
PHOTOMETRIC=YCBCR /tmp/T34WEB_20181015T104021_TCI_10m.jp2
~/T34WEB_20181015T104021_TCI_10m.jp2.ovr_geosolutions_jkak --config
GDAL_SKIP JP2OpenJPEG
Then compute stats on the file with gdalinfo -stats and I get the following:
gdalinfo -stats T34WEB_20181015T104021_TCI_10m.jp2.ovr_geosolutions_jkak
Driver: GTiff/GeoTIFF
Files: T34WEB_20181015T104021_TCI_10m.jp2.ovr_geosolutions_jkak
Size is 5490, 5490
Coordinate System is:
PROJCS["WGS 84 / UTM zone 34N",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",21],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","32634"]]
Origin = (499980.000000000000000,7700040.000000000000000)
Pixel Size = (20.000000000000000,-20.000000000000000)
Metadata:
  AREA_OR_POINT=Area
  Corder=LRCP
Image Structure Metadata:
  COMPRESSION=YCbCr JPEG
  INTERLEAVE=PIXEL
  SOURCE_COLOR_SPACE=YCbCr
Corner Coordinates:
Upper Left  (  499980.000, 7700040.000) ( 20d59'58.17"E, 69d24'34.71"N)
Lower Left  (  499980.000, 7590240.000) ( 20d59'58.25"E, 68d25'29.70"N)
Upper Right (  609780.000, 7700040.000) ( 23d47'41.77"E, 69d23'13.78"N)
Lower Right (  609780.000, 7590240.000) ( 23d40'24.01"E, 68d24'12.80"N)
Center      (  554880.000, 7645140.000) ( 22d22' 0.55"E, 68d54'42.54"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
*  Minimum=0.000, Maximum=0.000, Mean=0.000, StdDev=0.000*
  Metadata:
    STATISTICS_MAXIMUM=0
    STATISTICS_MEAN=0
    STATISTICS_MINIMUM=0
    STATISTICS_STDDEV=0
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
  Metadata:
    STATISTICS_MEAN=0
    STATISTICS_STDDEV=0
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
  Metadata:
    STATISTICS_MEAN=0
    STATISTICS_STDDEV=0
If I produce the overview file "on the fly" with gdaladdo I get a good
overview file instead:
gdaladdo -ro --config COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW
YCBCR --config
INTERLEAVE_OVERVIEW PIXEL  T34WEB_20181015T104021_TCI_10m.jp2 2 4 8 16 32
64 128
gdalinfo -stats  ./T34WEB_20181015T104021_TCI_10m.jp2.ovr
Files: ./T34WEB_20181015T104021_TCI_10m.jp2.ovr
Size is 5490, 5490
Coordinate System is `'
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 5490.0)
Upper Right ( 5490.0,    0.0)
Lower Right ( 5490.0, 5490.0)
Center      ( 2745.0, 2745.0)
Band 1 Block=128x128 Type=Byte, ColorInterp=Red
*  Minimum=0.000, Maximum=255.000, Mean=71.229, StdDev=62.445*
  Overviews: 2745x2745, 1373x1373, 687x687, 344x344, 172x172, 86x86
  Metadata:
    STATISTICS_MAXIMUM=255
    STATISTICS_MEAN=71.229008132023
    STATISTICS_STDDEV=62.445099566295
Band 2 Block=128x128 Type=Byte, ColorInterp=Green
*  Minimum=0.000, Maximum=255.000, Mean=66.111, StdDev=62.790*
  Metadata:
    STATISTICS_MEAN=66.110971363731
    STATISTICS_STDDEV=62.790298201369
Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
*  Minimum=0.000, Maximum=255.000, Mean=67.561, StdDev=63.721*
  Metadata:
    STATISTICS_MEAN=67.560742897336
    STATISTICS_STDDEV=63.721118995755
Any idea on what is causing this? I am using GDAL version 2.2.4
Thank you in advance
On Wed, Oct 17, 2018 at 11:53 AM Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> ---------- Forwarded message ---------
> From: jratike80 <jukka.rahkonen at maanmittauslaitos.fi>
> Date: Mon, Oct 8, 2018 at 1:08 PM
> Subject: Re: [gdal-dev] Creating external overviews for JP2 files?
> To: <gdal-dev at lists.osgeo.org>
> Hi Andrea,
> I had a try and it works for me with the gisinternals build "GDAL 2.4.0dev"
> with JP2OpenJPEG driver
> YCBCR --conf
> ig INTERLEAVE_OVERVIEW PIXEL  ovr.jp2 2 4 8 16 32
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> -Jukka Rahkonen-
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Regards,
> Daniele Romagnoli
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:      +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
Regards,
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
Alessandro Parma
DevOps Engineer
GeoSolutions S.A.S.
Italy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181017/aa8b3cdf/attachment-0001.html>
