[gdal-dev] [OSGeoLive] Issue #2068 on Mint 19
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Sep 16 08:23:37 PDT 2018
I thought we had fixed this issue some months ago...
Will look further into this.
Cheers,
Angelos
On Sat, Sep 15, 2018 at 4:43 PM Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 9/15/18 2:28 PM, Micha Silver wrote:
> > AFAIK, you don't necessarily need the ubuntugis repo in bionic distros.
> > The regular ubuntu repos have pretty recent versions. On my Mint systems
> > I get GRASS 7.4.0, and gdal 2.2.3.  But every invocation of gdal
> > commands begins with:
> > micha at TP480:~$ gdalinfo --version
> > ERROR 1: libgrass_dgl.7.4.0.so: cannot open shared object file: No such
> > file or directory
> > file or directory
> > ERROR 1: libgrass_vector.7.4.0.so: cannot open shared object file: No
> > such file or directory
> > GDAL 2.2.3, released 2017/11/20
> That's a known issue on Ubuntu based systems which build with
> --as-needed by default. A fix was added in libgdal-grass (2.3.0-2)
> triggered by https://trac.osgeo.org/osgeolive/ticket/2068.
> This fix is also available in libgdal-grass (2.2.3-3~bionic0) in the
> OSGeoLive PPA, but not in the ubuntugis-unstable PPA (any more). It's
> possible that a later rebuild of the libgdal-grass package reverted the
> fix.
> > And these errors are appearing also in R with the MODIS package.
> > What are the implications of adding the ubuntugis-unstable repo to solve
> > this?
> The libgdal-grass package in the UbuntuGIS PPA needs to be fixed. The
> older package from bionic most likely also doesn't have this fix.
> Kind Regards,
> Bas
> osgeolive mailing list
> osgeolive at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/osgeolive
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180916/61e1afbf/attachment.html>
