[gdal-dev] gdalwarp together with proj5 pipelines
Markus Metz markus.metz.giswork at gmail.com
Tue Sep 18 12:27:03 PDT 2018
On Tue, Sep 18, 2018 at 4:25 PM Dalia Prizginiene <dalia at lmi.is> wrote:
> Hello,
> Thank you for your reply, but that to be sure: does it mean that gdalwarp
at the moment does not allow also horizontal grid shift like
"+proj=hgridshift +grids=ISN93_16.gsb" or "+proj=latlong
 +nadgrid=xxxx.gsb" ?
the GDAL developers will be able to answer your question. As Even wrote,
"For now, you have to use -s_srs / -t_srs with projections method supported
by PROJ"
the above definitions could work as part of a -s_srs / -t_srs definition.
I was to referring to "+proj=pipeline ..." which is supported in GRASS GIS
7.6 if compiled with PROJ 5.x
Best regards,
Markus M
> Best regards
> Dalia
> ________________________________
> From: Markus Metz <markus.metz.giswork at gmail.com>
> Sent: Thursday, September 13, 2018 8:15:41 PM
> To: Dalia Prizginiene
> Cc: gdal-dev
> Subject: Re: [gdal-dev] gdalwarp together with proj5 pipelines
> On Thu, Sep 13, 2018 at 4:52 PM Dalia Prizginiene <dalia at lmi.is> wrote:
> > Hello,
> > Is it possible to use gdalwarp together with pipelines "+proj=pipeline
+step  +inv  +proj=lcc  +lat_1=64...
> > to transform the raster into different datum?
> > In here
http://osgeo-org.1560.x6.nabble.com/gdal-dev-proj-5-support-added-in-trunk-td5358899.html
it is said that "-ct" it could be used. But at the moment this option does
not work.
> > Maybe there is another option how to use gdalwarp together with
pipelines of proj5?
> Custom proj5-style pipelines are supported in GRASS 7.6, not yet
released. GRASS uses GDAL + PROJ for reprojection, and any testing on this
new feature would help those projects.
> In GRASS 7.6, you can define custom proj5-pipelines with r.proj
pipeline=...
> Markus M
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180918/04d4693c/attachment.html>
