[gdal-dev] Question about GDAL lib size
Patrick Valsecchi patrick.valsecchi at camptocamp.com
Tue Apr 2 00:14:35 PDT 2019
cmake -DCMAKE_BUILD_TYPE=Release ...
But typically the libs are not stripped in this mode either. I never
understood why and always add steps to do it afterwards.
On Tue, Apr 2, 2019 at 8:52 AM Fan Liu <fan.liu at ericsson.com> wrote:
> Hi,
> I tried ‘strip lib’, it reduce the lib file size to 17MB.
> Do you know is there any parameters during “./configure” to compile
> without debug? I didn’t find the document.
> BRs,
> Fan Liu
> *From:* Fan Liu
> *Sent:* Tuesday, April 2, 2019 2:40 PM
> *To:* Patrick Valsecchi <patrick.valsecchi at camptocamp.com>
> *Subject:* RE: [gdal-dev] Question about GDAL lib size
> Hi Patrick,
> Thanks for the reply.
> I checked online, it looks like strip a library will only remove unused
> links for debug.
> Is it possible to get confirm that strip a library will not impact
> functions?
> BRs,
> Fan Liu
> *From:* Patrick Valsecchi <patrick.valsecchi at camptocamp.com>
> *Sent:* Tuesday, April 2, 2019 2:27 PM
> *To:* Fan Liu <fan.liu at ericsson.com>
> *Subject:* Re: [gdal-dev] Question about GDAL lib size
> Hi,
> Most likely Redhat's is stripped and yours not. And yours is maybe also
> compiled in debug...
> Plus, you don't look at the same version of GDAL.
> To strip a library, use the "strip" command.
> CU
> On Tue, Apr 2, 2019 at 8:12 AM Fan Liu <fan.liu at ericsson.com> wrote:
> Resent question after register. Could anyone support?
> BRs,
> Fan Liu
> *From:* Fan Liu
> *Sent:* Tuesday, April 2, 2019 10:24 AM
> *To:* 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
> *Subject:* Question about GDAL lib size
> Hello,
> I have a question related with lib size. When I install GDAL via rpm on
> redhat, it lib size is 13MB. But when I compile GDAL frou source code on
> SUSE, the lib is 121MB. This confuse me, could anyone provide any
> suggestions? Why it's so big?
> -rwxr-xr-x 1 root root 121M Apr  1 08:37 libgdal.so.20.5.0  ## compile via
> source code 2.4.0
> -rwxr-xr-x  1 root root  13M Jan 28  2018 libgdal.so.1.18.4  ## installed
> via rpm on redhat
> BRs,
> Fan Liu
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190402/1ad57ef4/attachment-0001.html>
