[gdal-dev] Possible issue with alpha band and VRT
Even Rouault even.rouault at spatialys.com
Sat Apr 6 14:12:16 PDT 2019
Jukka,
> I repeated the steps which are described in this question
> https://gis.stackexchange.com/questions/317916/gdalbuiltvrt-output-is-diffe
> rent-than-the-source-images-when-using-dstalpha and it indeed seems that
> transparency that is defined with an alpha band in original images is lost
> if I read data through VRT.
gdalbuildvrt doesn't do alpha compositing (yet?). It you stack several images,
the non-alpha and the alpha band of the latest appearing in the sources will
be used, overriding completely what is beneath.
gdalwarp will do the right thing.
> I wonder if something similar happens than in
> this issue https://github.com/mapbox/rasterio/issues/1454 with
> GDALRasterBand::GetMaskBand().
>From a very quick look, no. The rasterio issue is about 16-bit images and mask
band
Even
http://www.spatialys.com
