[gdal-dev] installing gdal in CentOS
Markus Metz markus.metz.giswork at gmail.com
Sun Apr 7 12:57:23 PDT 2019
On Fri, Apr 5, 2019 at 3:38 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Apr 1, 2019 at 11:17 PM Andrew C Aitchison
> <andrew at aitchison.me.uk> wrote:
> > On Mon, 1 Apr 2019, Markus Neteler wrote:
> > > Now I am stuck at
> > > BUILD SUCCESSFUL
> > > Total time: 10 seconds
> > > + popd
> > > + %mvn_artifact swig/java/build/maven/gdal-2.3.2.pom
> > > swig/java/build/maven/gdal-2.3.2.jar
> > > ~/build/BUILD/gdal-2.3.2-fedora
> > > /var/tmp/rpm-tmp.R4QpDm: line 139: fg: no job control
> > > error: Bad exit status from /var/tmp/rpm-tmp.R4QpDm (%build)
> > That is probably a bug in the rpm .spec file
> >      https://www.redhat.com/archives/rpm-list/2002-October/msg00271.html
> > suggests that it is a % character being passed to the shell.
> Thanks Andrew,
> I made further attempts but I am stuck.
> Maybe the Python-3 support needs to be kicked out as well?
> The current state is here
> https://copr.fedorainfracloud.org/coprs/neteler/GDAL/build/876548/
> - SPEC file:
https://copr-be.cloud.fedoraproject.org/results/neteler/GDAL/epel-7-x86_64/00876548-gdal/gdal.spec
> - Log file:
https://copr-be.cloud.fedoraproject.org/results/neteler/GDAL/epel-7-x86_64/00876548-gdal/builder-live.log
In the log, there is
  File "/usr/lib/python3.6/site-packages/copr_rpmbuild/builders/mock.py",
line 40, in run
where is python 3.6 with /usr/lib/python3.6/site-packages/ coming from in
your build environment? Centos 7 comes with python 3.4 and gdal uses on
Centos 7 python -> python2. Maybe you need to drop this custom python3.6
installation. I never had any problems compiling gdal 2.x on derivates of
RHEL 7.
Markus M
> I'll continue with low priority, happily accepting support by
> more-than-me SPEC file experts.
> Best,
> Markus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190407/bb2126d5/attachment.html>
