[gdal-dev] libgeotiff 1.5.0 release candidate
Greg Troxel gdt at lexort.com
Mon Apr 8 12:44:55 PDT 2019
Even Rouault <even.rouault at spatialys.com> writes:
[I realize this is now about 1.5.1]
> The news are:
> * Require PROJ >= 6 dependency
> * Remove all CSV files used by geo_normalize API, since libgeotiff now relies
>   on PROJ database for EPSG CRS definitions.
> * geo_normalize.c: SetGTParmIds(): use ProjStraightVertPoleLongGeoKey for
> CT_PolarStereographic
> * geo_normalize.c: report StdParallel1 for Mercator_2SP when a PCS code is
> used
> * geo_normalize.c: fix support for Laborde Oblique Mercator
> * listgeo: use PROJ database to display non-hardcoded values of a number of
> keys
Because this requires proj 6, I can't update pkgsrc (well, I'm not
willing to move pkgsrc to proj 6 yet).   I realize there is only finite
effort, but it would be really nice if everything supported proj 5 and 6
both for a while, to avoid having to synchronize updates.
