[gdal-dev] How to run autotest
Even Rouault even.rouault at spatialys.com
Thu Apr 18 02:17:53 PDT 2019
> E   ImportError:
> /home/parallels/OS-GIS/platforms/linux/x86_64/gdal/lib/python2.7/site-packa
> ges/osgeo/_gdal.so: undefined symbol: CPLGetErrorCounter
Try
ldd /home/parallels/OS-GIS/platforms/linux/x86_64/gdal/lib/python2.7/site-packages/osgeo/_gdal.so
and check which libgdal.so it links to. It is likely that it is not the right one.
You'll have to adjust your LD_LIBRARY_PATH then.
Sourcing scripts/setdevenv.sh should do that for you
http://www.spatialys.com
